Fills - areas
i have a problem where if i create a fill and check show area and say the size id 2'X5' therefore 10 s.f. the fill text reads 0.93 s.f.. no matter what fill shape i do it always way under states the actual area. if i use zone tool it gets area correct.
anyone seen this with the area tool?
thanks
donald mac donald
V9, G-5 w/ OSX v 10.3.6
6 Replies 6
Aaron Bourgoin
Under Preferences verify that the Dimension preference for Fills is set to square feet.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
yes i checked that. its set to sq. ft.
none of my prefs that i can see are set to meters.
i'm at a loss.
thanks,
donald mac donald
Aaron Bourgoin
double click the view in the view set you're working from and verifiy the dimensioning prefs there. AC9 can remember dimension prefs for different viewsets. Very handy, but potentially problemmatic.
...riding shotgun down the avalanche....
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
0.93 is the area in m2.
There was another issue just yesterday that the Zone Settings Dialog displayed the are in m2 no matter what you set anywhere. On the Floor PLani s was correct, though.
Could be a bug.
i was able to correct the problem finally by changing at prefs-dimensions-areas from s.f. to meters. then back to a view then select a fill and it changed from the wrong s.f. number to the correct sq. meter number then back to prefs-dimensions-areas and reset to s.f. and then back to view and it changed to s.f. and area was correct.
thanks for your help.
donald mac donald
This also seems to help the coordiante label issue, but the leader lines still don't show.
Rip Weaver, ASLA
Archicad 9
Mac OSX 10.2.8
