Morphs can have Cover Fills on the Floor Plan. You probably have Cover Fill checked for these Morphs.
However, in 3D only the Surface assigned to the Morph is shown.
You can select any of the faces of the Morph using CTRL-SHIFT-click and assign a different Surface to each of its faces. The result of that will be visible in Elevation Viewpoints.
