2022-01-26 08:48 AM
How do I find the path of an existing program, so that I can add some more files to one of its directories?
The program has the registry information under:
SOFTWARE\GRAPHISOFT SE\Archicad 22\
The following code does not work for me:
#define PATH ReadReg(HKEY_LOCAL_MACHINE, "SOFTWARE\GRAPHISOFT SE\Archicad 22\")
DefaultDirName={#PATH}
2022-01-26 10:32 AM
Hello hamenkiakehna,
Archicad is available on 2 operating systems.
Perhaps you should tell which one you are talking to get a better answer ?
