2024-01-04
		02:37 PM
		2024-01-12
		03:48 PM
Hi there,
I wonder if there is any helper (like duplicate checker) to select all the elements in a plan view and then AC highlights the reference points that are really close to each other (according to some tolerance)? That could be a way to find drawn inaccuracies....
Thank you in advance..
2024-03-12 09:56 PM
Not that I know of. However, even very small modeling inconstancies will show up graphically when materials/surfaces are not perfectly aligned. A line will show up in a 3d view, Section, Elevation between elements for as little a .001" deviation - perhaps less - I didn't check for deviations smaller than that. If the elements are aligned perfectly, there will be no line between them.
2024-04-04 07:27 AM
Hello Steve,
thank you for your answer.
I just wondered if there is a tool for Archicad to pinpoint the inaccuracies for the whole project, because in a large scale project the solution you provide is not feasible.
