Fitting bottom of walls to mesh surfaces
How do we "trim" the bottom of a wall to sit correctly above a sloping mesh surface below.
I know I can trim to roof if I use a "roof slab" instead of the mesh but in my case the mesh works better.
Any ideas ?
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
David Pacifico
Couple things to try.
1. Solid Operations. Use the mesh to subtract the walls with a downwards extrusion.
2. In the goodies folder there is an add-on that can turn your mesh into roofs.
David Pacifico, RA
AC27 iMac i9, 32 gig Ram, 8 gig video Ram
Clever !
I like the first one and I will search for the second one.
Thanks David.
