Floor Plan Change
Let's say you have a 10x10 2 story structure with roof and foundation already done. Is there an easy way to change it to a 10x8 or 10x12 structure all at once? Or is doing each floor, roof, and foundation separately the only way to do it?
Thanks,
Rich
Check in the Documentation the use of the Marquee Tool. You will need the Thick Marquee as it will allow you to make stretch operations on all stories at the same time.
Djordje
... making sure that the grouping is off, and that all the layers are visible and unlocked. That is, if you want to stretch everything; the things you want to keep as they are (site stuff for example) should stay locked in this case.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
