‎2006-10-14 05:58 PM
‎2006-10-15 11:01 PM
Roman wrote:roman
How can I have a different height of the Cut Plane for each story?
‎2006-10-16 07:39 PM
‎2006-10-16 07:48 PM
Roman wrote:The cut plane does not affect any object-based tools except doors & windows, and even them only slightly
Thanx Ben
Just wonder, as the cut plane doesn't affect the display of stairs, whether there's option making stairs to display themselves according to the floor plan cut plan settings. I read that they can be programmed this way but have no clue how. But this is GDL issue rather, I guess.
Roman
‎2006-10-16 08:58 PM
Roman wrote:You will also have to remember to switch between Stories by double-clicking the appropriate saved View in the Navigator - this way the stored Floor Plan Cut Plane setting gets applied, too. Whereas, if you just go from one Story to another, the Floor Plan Cut Plane setting stays the same.
Thanx Ben
Roman
‎2006-10-16 09:05 PM
TomWaltz wrote:Unless they've been scripted to respond to it.
‎2006-10-16 09:32 PM
Matthew wrote:OK.... The cut plane does not affect any GRAPHISOFT-PROVIDED object-based tools except doors & windows, and even them only slightlyTomWaltz wrote:Unless they've been scripted to respond to it.
‎2006-10-16 10:29 PM
TomWaltz wrote:I forgot to add that such creatures have yet to be spotted in the wild (AFAIK)Matthew wrote:OK.... The cut plane does not affect any GRAPHISOFT-PROVIDED object-based tools except doors & windows, and even them only slightlyTomWaltz wrote:Unless they've been scripted to respond to it.
The cut plane does not affect any object-based tools except doors & windows, and even them only slightly😉
