Floor deck modelling help
Greetings,
I am in great need of a Lib part for corrugated metal deck. I have no idea how to work with the one published in the GDL Depository of this Forum.
Decking footprint has an irregular shape, so edges editing is a must.
Any guidance to satisfy the above will be appreciated
Win 10 Home Premium - AMD Phenom IIX6 1090T Processor 3.20 GHZ 8.00 GB RAM 64-bit Opp. Sys NVIDIA Quadro 4000 AC 22, MEP
Dwight
Other solutions:
1: Special Archicad Downloadable tools:
http://www.graphisoft.com/ftp/techsupport/downloads/goodies15/ReadMe/Accessories/00_Accessories.htm
See Help menu for "Archicad Downloads > Accessories"
2: Use of complex profile [wall, beam] defining extrusion and SEO defining shape.
Dwight Atkinson
Conrado,
Use the object in the AC14 Library (Profiled Sheet Inc 14) or that in Depository.
To obtain a free-form contour draw a slab that intersect the sheet and use SEO (Intersection). Then save the modified sheet fom 3D View (view from TOP, Azimuth 270°) as OBJECT (Non-editable 3d Binary data). In this way contours in 2D view are correct.
Thanks for your help.
Up and running again !
