2023-07-07 08:15 AM
How to show floor finishes on a plan?
Zone.... but if I want to use the zone on other plans I have to use an GO which I only managed to use by saying the hatch should be overriden with a white pen. Now my kitchen object has small gaps caused by it.
Hatch. But that sounds like not very advanced
Accessories? Not used it before but wondering whether that is better?
Needs to work with schedules later too
2023-07-07 09:27 AM
What about slab cover fills?
2023-07-07 09:32 AM
Doesn't that mean for each room a different slab?
2023-07-07 09:41 AM - edited 2023-07-07 09:41 AM
It depends on the finish and structure but yes.
For example, living room and bedroom could be the same, but bathroom would be different.
I always separate structural slabs and finishing slabs, so my structural slab is one building material for the whole story, but finishes are composites with different skins.
2023-07-07 10:42 AM
can put directly an image fill in the zone tool granting you have divided the spaces accordingly.
2023-07-08 07:10 PM
I’ve found the only way to really get it right is to use morphs for each floor finish. You can have different materials, different surfaces, attach data and schedule. Morphs crucially cut through door openings where slabs are tricky
2023-07-08 09:10 PM
I managed to get hold off the graphisoft hotline snd we found a GO which turned the hatch from the zone off on the plans we don't need it.
What are the reasons for people to add an extra slab or morpth if you can achieve it with zones???
2023-07-10 07:08 AM
It is not extra, I need it for my model, sections, etc..
2023-07-11 12:04 PM
Hi Tim Slabs work well because there's an ArchiCad rule to help with door openings.
If a Slab skin is defined as "Finish" it won't be cut and pass thru any door opening based aligned with the top off finish skins regardless of Material priority.
2023-07-12 04:03 PM
We model it with slab per finish (some finishes cover multiple rooms).
We generally have a very low building material strength, so even if you draft it sloppily, it should clean up in sections. However if you want a nice cover fill, it is better to draft it correct.
Often times we only have bathrooms with floor tiles to show as the end user will install floor finishes after receiving the keys.
