Learn more
Floor plan cut plane problem
If my FPCP is set to 1,00m why dont I see any cut fills on the floor plan that go throu my beams and slabs?
See attached picture and ac file, section display
http://rapidshare.com/files/223649485/cutplane.pln.html
1 Reply 1
Thomas Holm
Archicad's Floor plan is largely symbolic, not completely a true 3D cut at the FPCP. If you need that, you can make a 3D cut top view in the 3D window, and either make a 3D document of it or overlay the cut view (copy+paste) on the floor plan.
