Folder organization
Hello,
Is it possible to transfer this type of folder organization from one project to another ?
But without :
- an addon
- a third-party software
- the tpl file because it does not deals with new project
Christophe - FRANCE
Formateur Archicad indépendant à NANTES, PARIS
Archicad 15 to 29
Erwin Edel
As far as I know, it is only possible with layout book folders. This would save a lot of time fixing templates and such, but I suppose it is impossible to recreate cloned view links and folders and so on between projects by drag and drop.
The way to achieve it would be through the Organizer where you can have two seperate files open, but that only leaves the layout book as possible option for the target file.
I am actually currently re-working our template for AC23 (late to the party!) and it is taking quite some time to recreate our entire view map tree with all the folders and views set up for different stages, structural drawings etc. I decided it would be a good time for a 'fresh' template, without any possible 'polution' from previous versions, so I am reworking the stock template to our needs.
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
