Foundation Method
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2004-03-09
06:16 AM
- last edited on
ā2023-05-25
06:05 PM
by
Rubia Torres
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 01:17 AM
Matthew wrote:I'm sorry...duh my head was somewhat elsewhere, I should have checked and said. I am not at my blessed (keyed) computer, so even though AC is on... it I can check how it was set up. My template is fairly old.. so am I. I think the composite is set with a solid heavy line, and it is overridden in the tool setting with a dashed line. Section is set to use composites settings. If that is not right I will check when I get back to the office. Since I work at home it would not be a problem.
So Rick,
Tell us how you do it. I can't find any setting that fixes it as you show. Inquiring minds want to know.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 05:41 AM
I'll have to check it when I've got AC running. Unfortunately this ends us up with another partial work-around, making the new composites line types only partially functional.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 06:47 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 12:38 PM
I think you should go ahead and post the wish. Rick's method is a partial workaround and I am pretty sure there is no other way. The only question is how it should be done. It seems it could either be fine tuned control in the composite settings or a simple override in the element's section settings (or both).
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 03:37 PM
It seems that in 8.1 the Wall Tool linetype selected for the plan also applies to the section, so...some good thoughts on work-arounds have been suggested:
1. Define a composite wall to display the 2D footing as dashed - downside being that you're constricted to a predetermined width.
2. Define the Wall Tool linetype as dashed - downside is you've got to trace the sections with a solid line (easy but not elegant).
3. Create a footing symbol to undercut the foundation wall - downside being that you need some GDL skills to manage this elegantly.
4. Create a "footing" wall and "chop the top" using empty window symbols and define the window sills as dashed lines - downside ... fussy.
5. Put the footing wall on a separate layer for "3D display only" and simply draw the 2D dashed lines.
I think Flamer has found a weak link in the wall tool display - the plan linetype and section/elevation linetype shouldn't be linked. In any event, any thoughts on which of the five scenarios would offer the best solution?
I'd guess number 2 would be OK as a quick workaround - 3 would be preferable for those versed in basic GDL.
Cheers, Cameron
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 03:39 PM
Matthew wrote:I have to defend GS on this one. I think the system allows you to do whatever you need, with great flexibility. I am not sure what your wish is, you can already have what you want with one simple tool setting. Maybe I am missing something, but it is quick to do without any fuss, solid in section, and dashed (or not) in plan... for any composite.
Thanks Rick.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 03:46 PM
Vitruvius wrote:I find having predetermined widths a valuable tool. It is fast to select the appropriate footing without setting anything, and more important allows linking a property script to each defining appropriate rebar. Laying out a foundation is very fast having these predetermined... there are normally only so many, at least for me.
Well, I think we've totally confused poor Flamer.
Cheers, Cameron
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 05:17 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-03-10 05:52 PM
Flamer wrote:this screen shot (actually 2 stuck together) has all the settings for the composte wall and for the tool. If this is not clesr ask, but it is probably better than I could describe...
Rick, Could you elaborate on how you are getting dashed in plan / solid in section? If you are using 2D lines, thats fine I can live with that for now, but I don't want to miss out if there is a more direct way (Through settings ect.)
