2004-03-09 06:16 AM - last edited on 2023-05-25 06:05 PM by Rubia Torres
2004-03-10 01:17 AM
Matthew wrote:I'm sorry...duh my head was somewhat elsewhere, I should have checked and said. I am not at my blessed (keyed) computer, so even though AC is on... it I can check how it was set up. My template is fairly old.. so am I. I think the composite is set with a solid heavy line, and it is overridden in the tool setting with a dashed line. Section is set to use composites settings. If that is not right I will check when I get back to the office. Since I work at home it would not be a problem.
So Rick,
Tell us how you do it. I can't find any setting that fixes it as you show. Inquiring minds want to know.
2004-03-10 05:41 AM
2004-03-10 06:47 AM
2004-03-10 12:38 PM
2004-03-10 03:37 PM
2004-03-10 03:39 PM
Matthew wrote:I have to defend GS on this one. I think the system allows you to do whatever you need, with great flexibility. I am not sure what your wish is, you can already have what you want with one simple tool setting. Maybe I am missing something, but it is quick to do without any fuss, solid in section, and dashed (or not) in plan... for any composite.
Thanks Rick.
I'll have to check it when I've got AC running. Unfortunately this ends us up with another partial work-around, making the new composites line types only partially functional.
2004-03-10 03:46 PM
Vitruvius wrote:I find having predetermined widths a valuable tool. It is fast to select the appropriate footing without setting anything, and more important allows linking a property script to each defining appropriate rebar. Laying out a foundation is very fast having these predetermined... there are normally only so many, at least for me.
Well, I think we've totally confused poor Flamer.
1. Define a composite wall to display the 2D footing as dashed - downside being that you're constricted to a predetermined width.
Cheers, Cameron
2004-03-10 05:17 PM
2004-03-10 05:17 PM
2004-03-10 05:52 PM
Flamer wrote:this screen shot (actually 2 stuck together) has all the settings for the composte wall and for the tool. If this is not clesr ask, but it is probably better than I could describe...
Rick, Could you elaborate on how you are getting dashed in plan / solid in section? If you are using 2D lines, thats fine I can live with that for now, but I don't want to miss out if there is a more direct way (Through settings ect.)
