2011-01-29
01:55 AM
2023-05-23
04:45 PM
Rubia Torres
2017-04-13 07:21 AM
s2art wrote:FILE menu > File Special
First up - where has the "Place mesh from Surveyors Data" command gone? Doesn't seem to be in the design menu in AC20 (it is in AC19).
s2art wrote:Take the last 3 columns? and place them under the first 3?
Second - does anyone understand line 5 in Nando's description?5- take the last 3 and place them at the end so you can have a list of X, Y and Z valuesI don't quite understand.
The procedure to obtain this TXT file was:
1- Open the DWG as an Object
2- Copy the 3D script and Paste it into a simple text editor like Notepad/Textedit
3- Save it as TXT
4- Open the TXT in MS Excel
5- Clean the content in order to obtain separate columns with X,Y,Z values
6- Save it again as (the final)TXT
s2art wrote:Not sure about this one.
I do re-save as a .txt file (without step 5) but I keep getting an error message saying "The selected file is not a Text files (*.txt) file. Please select a valid Text files (*.txt) file."
2017-04-14 01:03 PM
2017-04-14 01:35 PM
mikas wrote:The color values are needed for Point Clouds, not for Surveyor's Data input. Here is an article I wrote a while ago about importing X, Y, Z values via the Place mesh from Surveyors Data command: Creating a Mesh from a txt file.
The last time I checked (ACv19), there needs to be color values too in xyz -format. ArchiCAD will not read the .xyz point cloud without color information embedded in the table.
2017-04-14 01:46 PM
David wrote:Whoops. Thank You for the link btw.mikas wrote:The color values are needed for Point Clouds, not for Surveyor's Data input. Here is an article I wrote a while ago about importing X, Y, Z values via the Place mesh from Surveyors Data command: Creating a Mesh from a txt file.
David
2017-04-15 02:11 PM
mikas wrote:No worries. I am pleasantly surprised at how well non-native English speakers can participate in this forum. Without screen shots the cross referencing of commands must be difficult.
ps. Daily I'm using a finnish version of the ArchiCAD. Sorry for my misinterpretations. I do have to launch the international version of AC sometimes to match some vocabulary. You would not believe how different the vocabulary can be.
2017-04-30 11:28 PM
Barry wrote:Had some success with your suggestions, Barry, thank you. But then I found a document on our system written by a former employee which said to delete the last 3 columns (not place them under the others). Seemed to give better results, albeit from a different DWG file.s2art wrote:FILE menu > File Special
I am not sure - been a long time since I tried it.
What you should end up with is 3 columns for the x,y & z values.
Nando did list a slightly different set of instructions but maybe because that was for a diffent file?
3- Save it as TXT
6- Save it again as (the final)TXTs2art wrote:Not sure about this one.
2017-05-30 09:02 AM
2018-05-02 11:16 AM
2018-05-02 11:34 AM
2018-05-02 01:01 PM
