2008-10-13 11:06 AM
2008-10-13 02:00 PM
2008-10-14 06:10 AM
2008-10-14 11:32 AM
2008-10-15 01:56 AM
mangaisonu wrote:An easy way to find out is to try and assign a command to the F keys in your Work Environment Shortcuts. You will then see the following in the default AC12 Shortcut Scheme:
i understand that, but my question is....... only for function keys from F1...F12. i found for few....so i wanted to know whether is anything else available.
ANY HOW THANKS........
2008-10-15 10:50 AM
2008-10-15 08:42 PM
Link wrote:Hi Link:mangaisonu wrote:An easy way to find out is to try and assign a command to the F keys in your Work Environment Shortcuts. You will then see the following in the default AC12 Shortcut Scheme:
F1 Help [hard coded - can't be reasigned]
F2 Floor Plan
F3 Open 3D Window
F4 Currently not assigned to any command
F5 Show Selection/Marquee in 3D
F6 Last Selection (context menu)
F7 Last Layout (context menu)
F8 Currently not assigned to any command
F9 Currently not assigned to any command
F10 Currently not assigned to any command
F11 Currently not assigned to any command
F12 Currently not assigned to any command
Link.
2008-10-16 01:13 AM
mangaisonu wrote:And your happiness is what I'm here for.
thank u link....i m happy with your answer
Don wrote:I think I better let a Mac person answer that. I should have been more clear and said that the above is for PC (I just don't think there's even a single Mac in India!
Hi Link:
I'm on Mac and going back years to Quickeys, I have always had (and still do) F1 assigned to Zoom In. Is a Mac/PC thing?
Don Lee
