Function keys in ArchiCAD 12
Please kindly say what are the functions of Function keys in ArchiCAD 12
From F1,F2........F12.
for example like F2- floor plan (short cut)
7 REPLIES 7
IN The Options\Work Environment\Keyboard Shortcuts page you can click the Show Shortcut List in Browser button and all shortcuts will be listed in you default web browser.
i understand that, but my question is....... only for function keys from F1...F12. i found for few....so i wanted to know whether is anything else available.
ANY HOW THANKS........
The current asssignment of F keys you will find in that generated list in your browser.
Otherwise you are free to assign any shortcut key to any of those F keys, you can even change their assignment if you want.
Link
An easy way to find out is to try and assign a command to the F keys in your Work Environment Shortcuts. You will then see the following in the default AC12 Shortcut Scheme:
F1 Help [hard coded - can't be reasigned]
F2 Floor Plan
F3 Open 3D Window
F4 Currently not assigned to any command
F5 Show Selection/Marquee in 3D
F6 Last Selection (context menu)
F7 Last Layout (context menu)
F8 Currently not assigned to any command
F9 Currently not assigned to any command
F10 Currently not assigned to any command
F11 Currently not assigned to any command
F12 Currently not assigned to any command
Link.
thank u link....i m happy with your answer
F2 Floor Plan
F3 Open 3D Window
Link.
Hi Link:
I'm on Mac and going back years to Quickeys, I have always had (and still do) F1 assigned to Zoom In. Is a Mac/PC thing?
Don Lee
Link
And your happiness is what I'm here for.
Don wrote:
Hi Link:
Don Lee
I think I better let a Mac person answer that. I should have been more clear and said that the above is for PC (I just don't think there's even a single Mac in India! ).
Mac has OS keyboard shortcuts (ie. Cmd+D for Dock?) and I'll leave it to somene who works with them day in and day out to list them and how they are overridden.
Link.
