GSM Properties - Windows
Link
This may be obvious to some users, and while I don't claim to be a GDL guy, I just found it out. On a PC, if you right click on a library part and select 'Properties', you can find out many things about the part, including the scripts and preview info.
Check out the attachment. The same thing probably exists on a mac's 'Get Info' dialog.
If you already knew this - I'd believe you!!
Link.
0 REPLIES 0
