2022-08-17 04:12 PM
Hello everyone
I am new in this forum, I would like to ask for your help. I have this small problem
I don´t know but the stair has a gap in section, do you know how I can fix it?
thanks a lot in advance for your help.
Marco
Solved! Go to Solution.
2022-08-17 05:09 PM
this should fix it: https://capture.dropbox.com/MbI63eP5yNNDy2lt
2022-08-18 12:04 PM
not a very 'neat' solution but it does fix your problem:
https://capture.dropbox.com/zrntxNqPCiADfLwb
2022-08-17 05:09 PM
2022-08-17 05:52 PM
It worked perfectly thank you Emre! now that we are chatting do you know how to solve this issue? I would like that the stair rest will be the same line with the stair steps, becuause there is a gap, unfortunately the "landing options are in 0" so I really don+´t know how to change it, so in case you know I will really appreciate your help, thank you so much in advance
2022-08-17 06:44 PM
can't really think of a direct solution, but if you care to share your file - or perhaps a file with just that stair - i can (and perhaps others as well) take a look.
2022-08-17 07:17 PM
Thanks Emre
sure no problem, how can I send the file?
2022-08-18 11:36 AM
2022-08-18 12:04 PM
2022-08-18 12:35 PM
thanks a lot for the solution Emre!
all the best!
2022-08-21 10:45 PM
we could also change the reference line to the inner part
