mrco
Gap in the stair
Hello everyone
I am new in this forum, I would like to ask for your help. I have this small problem
I don´t know but the stair has a gap in section, do you know how I can fix it?
thanks a lot in advance for your help.
Marco
2 Solutions
Emre Senoglu
this should fix it: https://capture.dropbox.com/MbI63eP5yNNDy2lt
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Go to post
Emre Senoglu
not a very 'neat' solution but it does fix your problem:
https://capture.dropbox.com/zrntxNqPCiADfLwb
Go to post
8 Replies 8
Emre Senoglu
mrco
It worked perfectly thank you Emre! now that we are chatting do you know how to solve this issue? I would like that the stair rest will be the same line with the stair steps, becuause there is a gap, unfortunately the "landing options are in 0" so I really don+´t know how to change it, so in case you know I will really appreciate your help, thank you so much in advance
Emre Senoglu
can't really think of a direct solution, but if you care to share your file - or perhaps a file with just that stair - i can (and perhaps others as well) take a look.
mrco
Thanks Emre
sure no problem, how can I send the file?
mrco
Hi Emre
here is the file with the stair, hopefully it is possible to solve the problem
thank you very much in advance
Marco
Emre Senoglu
mrco
thanks a lot for the solution Emre!
all the best!
Julio C Freitas
we could also change the reference line to the inner part
