Ghost Mark in multiple copy
In archicad 18 when a multiple copy of a door or window on the same wall is done, leaving a ghost mark is not removed until a new element copy, and freeze when press the escape bottom... Can you help? .. Thanks
win7 core i7 12gb ram 1tb hdd ati FirePro 5800 updated drivers.
3 Replies 3
I would be guessing that the ghost copy you are seeing is actually that your "Trace & Reference" is turned on.
Open the T & R dialogue and press the top-left button to turn it off.
Hi thanks for replying ... the problem is associated with the 3d view ... after removing the window or door copied several times, is a phantom mark on the wall and not removed until copy a new element also presents problems copy multiple windows or doors in 3d space action work after the escape key is pressed to release the cursor freezes archicad then ... thanks for any suggestions
This might be some graphics card driver problem.
Usually when strange items are left on the screen, that is a sign for such a problem
Try to update your drivers and see if that helps.
