Ghost walls
jss
Archicad 20 - old (ghost) walls, perpendicular, keep showing through a wall it used to connect too. I tried turning off the 'Clean Walls and Intersection' under Trace Wall , but then bold lines with the arrows show up. Does anyone help to get rid of these breaks in the walls from old walls that are not there anymore. In model view, the real wall has cut outs where the old removed wall was.
Thank you Jill
1 REPLY 1
jss
I figured out the problem.  There was a duplicate layer that was turned on with an old version of the plan....Sorry to bother eveeryone.
