2006-06-26 02:56 AM
2006-06-26 03:43 AM
sylvain wrote:AC9 and the original AC10 release do not support MacIntel at all. There is an Archicad 10 MacIntel version in testing currently. My reseller tells me it's due in July.
I am working on Revit since 2003 ( version 5.0), it is easy to see that ArchiCad is way in front. compability they will tell you... Thanks to Revit version 9.0, now it is easier to <translate> your work in Autocad, for <the others>. Anyway, Autodesk's product are compatible with each other only in <our minds> they are selling you < Autodesk >
Can somebody tell me if ArchiCad 10 is supported by the new Apple-Intel Technology and the new OSx ? So I can switch now.
2006-06-29 08:50 AM
TomWaltz wrote:While not officially supported, AC9 and 10 both run quite well under Rosetta (10 is a bit slower but I am using it with no difficulty for real work). I can recall only two crashes with AC10 on my MacBook Pro and none in AC9. I am constrained from reporting about the Mactel beta - but I think it's safe for me to say that you have nothing to worry about.
If you are running Windows on the MacIntel, I understand the Windows version of AC10 runs quite well.
2006-06-29 09:23 PM
2006-06-30 05:24 AM
2006-07-13 07:55 AM
2006-07-13 06:22 PM
"sylvain" wrote:
I went recently to a <smoke show> of Archicad. Unfortunately it was a disaster too.
C'mon give the guys a break. There is a lot to learn with this one, If your show was a disaster it was probably due to just being so new in the market. Typically the dealers don't get their hands on it till a week before it's release.
2006-07-13 06:32 PM
sylvain wrote:In Teamwork one can marquee an empty space not associated with the model and not have to reserve a layer or ask permissions... just send and receive. The existing model can not be edited with this method...but I like that especially if it is ready to embellish w/ dims and notes.
Patience my friend. Teamwork in Archicad looks easier and more logical. Anyway, I am very anxious to switch to Archicad...
2006-08-22 01:52 AM
2006-08-22 04:47 AM
