ā2022-08-04 04:23 PM
good morning, simple problem. I want to show new walls in plan with a hatch. the Renovation Filter > Floor Plans > Graphic Override Rules is showing a hatch for New Elements, but walls that are designated New are still showing up as white, without the hatch. thanks, margaret
Solved! Go to Solution.
ā2022-08-04 05:10 PM
Do you have selected override for New Elements?
ā2022-08-04 05:21 PM
You should check Filter Settings in Renovation Filter Options, if you have selected "Override" for New Elements, as picture above.
ā2022-08-04 05:00 PM
Good evening.
Check if you have Override Cover Fill Background for New Elements in GO settings
ā2022-08-04 05:03 PM
ā2022-08-04 05:04 PM
thanks, I think I do, see picture...still not working?
You don't have any other Graphic Override rules applied do you? Graphic overrides will take precedent over renovation overrides. make sure your graphic Overrides are set to none and see if it works then.
ā2022-08-04 05:11 PM
Make sure your Renovation Filter is set to a filter type that is configured to override 'new' elements.
ā2022-08-04 05:16 PM
no, and I'm sure wall in question is "new item" on renovation pallet.
ā2022-08-04 05:22 PM
that's it! thanks Andrii. I'm just coming to Archicad from Revit, and I'm baffled by the number of options.....
