mserrato
Graphic Override for New Walls
good morning, simple problem. I want to show new walls in plan with a hatch. the Renovation Filter > Floor Plans > Graphic Override Rules is showing a hatch for New Elements, but walls that are designated New are still showing up as white, without the hatch. thanks, margaret
2 Solutions
Andrii Levko
Do you have selected override for New Elements?
Andrii
AC 8.1 - 28 INT/POL 3001
Win11
Go to post
Andrii Levko
You should check Filter Settings in Renovation Filter Options, if you have selected "Override" for New Elements, as picture above.
Andrii
Win11
Go to post
10 Replies 10
Andrii Levko
Good evening.
Check if you have Override Cover Fill Background for New Elements in GO settings
Andrii
Win11
mserrato
mserrato
thanks, I think I do, see picture...still not working?
Andrii Levko
Andrii
Win11
Lee Hankins
You don't have any other Graphic Override rules applied do you? Graphic overrides will take precedent over renovation overrides. make sure your graphic Overrides are set to none and see if it works then.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Lee Hankins
Make sure your Renovation Filter is set to a filter type that is configured to override 'new' elements.
Lee Hankins
macOS Tahoe (26.0)
mserrato
no, and I'm sure wall in question is "new item" on renovation pallet.
Andrii Levko
Andrii
Win11
mserrato
that's it! thanks Andrii. I'm just coming to Archicad from Revit, and I'm baffled by the number of options.....
