‎2022-08-04 04:23 PM
good morning, simple problem. I want to show new walls in plan with a hatch. the Renovation Filter > Floor Plans > Graphic Override Rules is showing a hatch for New Elements, but walls that are designated New are still showing up as white, without the hatch. thanks, margaret
Solved! Go to Solution.
‎2022-08-04 05:10 PM
Do you have selected override for New Elements?
‎2022-08-04 05:21 PM
You should check Filter Settings in Renovation Filter Options, if you have selected "Override" for New Elements, as picture above.
‎2022-08-04 05:00 PM
Good evening.
Check if you have Override Cover Fill Background for New Elements in GO settings
‎2022-08-04 05:03 PM
‎2022-08-04 05:04 PM
thanks, I think I do, see picture...still not working?
You don't have any other Graphic Override rules applied do you? Graphic overrides will take precedent over renovation overrides. make sure your graphic Overrides are set to none and see if it works then.
‎2022-08-04 05:11 PM
Make sure your Renovation Filter is set to a filter type that is configured to override 'new' elements.
‎2022-08-04 05:16 PM
no, and I'm sure wall in question is "new item" on renovation pallet.
‎2022-08-04 05:22 PM
that's it! thanks Andrii. I'm just coming to Archicad from Revit, and I'm baffled by the number of options.....
