Grid Element Tool
Zdenko
any particular reason when placing grid elements the bottom and right side are not symmetrical to the top and left side in terms of offset from object being used for showing the grid elements? or is there a setting that can fix this.
Archicad 27 5030 USA Full Apple
M3 Max 36GB MacBook Pro
Sequoia 15.1.1
aarkell
I believe the grid offset is in relation to the total length of the gridline? So if that slab wasn't centered on the north/south gridline (up/down line) then it wouldn't be evenly spaced from it's edges. If you make the gridline length such that it was offset the same distance from each slab edge it would be the same?
Andrew Arkell
AC 18-27 USA 5030
HP Z6 G4 Workstation | Intel(R) Xeon(R) Gold 6226R CPU @ 2.90GHz | Windows 11
not following what you are trying to convey? the grid design system tool automatically generated the grid with no graphical modifications from my end. I also don't see any flexibility with regards to offset within the interface.
Sequoia 15.1.1
finally figured out that i was in the wrong interface and what i was looking for is under pulldown menu "design" then select "grid system". had to go through several iterations to understand what each of the settings had to offer and eventually was able to get what was needed.Screenshot 2024-10-23 at 1.23.03 PM.png
Sequoia 15.1.1
