Too Long
Cladding in window reveal
I have vertical aluminium batten cladding terminating against the window frame but the window opening cuts the cladding and exposes the wall behind.
This is modelled with a complex profile column.
Is there a way to model this so thatt he battens are visible inside the reveal?
AC26 AUS Full
1 Solution
cuba
Make sure that the building material of the cladding is higher then the building materials of the wall.
Apple M1 Max 32 GB
Latest AC
Go to post
3 Replies 3
Lingwisyer
Guru
I would put the cladding on a seperate layer and set the Intersection Group to something unique.
Ling.
Win11 | i9 10850K | 64GB | RX6600 Win11 | 5900X | 32GB | GTX2080TI
cuba
Apple M1 Max 32 GB
Latest AC
Too Long
So simple, thank you so mucj
AC26 AUS Full
