Cladding in window reveal
Too Long
I have vertical aluminium batten cladding terminating against the window frame but the window opening cuts the cladding and exposes the wall behind.
This is modelled with a complex profile column.
Is there a way to model this so thatt he battens are visible inside the reveal?
AC26 AUS Full
cuba
Make sure that the building material of the cladding is higher then the building materials of the wall.
Apple M1 Max 32 GB Ventura
AC27
Lingwisyer
Guru
I would put the cladding on a seperate layer and set the Intersection Group to something unique.
Ling.
cuba
AC27
So simple, thank you so mucj
AC26 AUS Full
Setup info provided by author
