2024-10-23 05:58 AM
I have vertical aluminium batten cladding terminating against the window frame but the window opening cuts the cladding and exposes the wall behind.
This is modelled with a complex profile column.
Is there a way to model this so thatt he battens are visible inside the reveal?
Solved! Go to Solution.
2024-10-23 09:10 AM
Make sure that the building material of the cladding is higher then the building materials of the wall.
2024-10-23 09:02 AM
I would put the cladding on a seperate layer and set the Intersection Group to something unique.
Ling.
2024-10-23 09:10 AM
2024-10-23 11:07 PM
So simple, thank you so mucj
