‎2014-01-14 01:54 PM
‎2014-01-14 02:07 PM
‎2014-01-14 03:29 PM
Keith wrote:You can select any group and lock them manually with the Lock command. If you assign a key shortcut to the Lock command then it is pretty fast and easy to do. You can actually do this right after creating the group.
Alternatively, I wonder if there couldn't be a 'locked' status for groups that you would never want to stretch (or modify in any way). Then, grouped items would stretch along with other elements (with grouping turned on) unless the group was 'locked'.
Any thoughts?
‎2014-01-15 11:40 AM
‎2014-01-15 05:12 PM
‎2014-01-15 05:48 PM
‎2014-01-15 06:00 PM
‎2014-01-15 07:55 PM
Keith wrote:You can use the Selections palette (Window>Palettes>Selections) for this.
I think it's often done as a way of 'recording' a selection of objects in case you wish to repeat the selection.
‎2014-01-15 10:49 PM
David wrote:Same with me!
This is one reason I still have the Control Palette displayed in my Work Environment, it shows the current Group/Suspend Group status.
‎2014-01-15 11:51 PM
kliment wrote:Yep, doesn't take long to check when you need to (although I do forget occasionallyDavid wrote:Same with me!
