No Copy Paste from Multiple Storeys
Here's a new one for me. Has anyone come up with the attached message when copying and pasting from plan to elevation? It just involves 2D lines, text and fill.
12 Replies 12
Wait, it works when I suspend the groups of entities so am still perplexed.
Link
Your group must have included elements from multiple stories. Easy to do when you have them displaying on multiple stories or group via the 3D window, section, elevation, etc.
Enable groups, select it, go to the 3D window and find the culprit(s)!
Link.
Thanks Link.
Does this phenomenon occur with 2D elements if they were drawn in another storey? That is odd. I am only copying a set of grouped entities comprising arcs fills and text from the model space, which is a manual door/window schedule marker in 2D only, to an elevation window.
Link
Are you saying that you're copying 2D elements that make up a manual window/door marker, from the floor plan to an elevation?
Link.
Hi, yes Link, that's all I needed to do. It works if I suspend the groups. Cheers.
Link
Sorry, that just posed more questions than it answered!
I can't think of how that could occur with 2D elements, but that's not to say it wouldn't.
Just to be sure if you select the group, with grouping enabled, and go to Edit Selection Set, what does it list?
Link.
Glad to help Link, thanks.
Link
And that's with Grouping enabled hey? That's curious.
If you want to save it as a module file and upload a zip of it, I'll happily take a look!
(just select the whole group, copy to clipboard, go to file saves as> module from clipboard, then zip it and upload it here)
Link.
Link
BTW One of the questions your post posed was why are you coping text and lines for window markers from floor plan to elevation?
You can achieve this with (semi) automatically with window markers and labels.
Link.
