Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
Here's a new one for me. Has anyone come up with the attached message when copying and pasting from plan to elevation? It just involves 2D lines, text and fill.
Your group must have included elements from multiple stories. Easy to do when you have them displaying on multiple stories or group via the 3D window, section, elevation, etc.
Enable groups, select it, go to the 3D window and find the culprit(s)!
Thanks Link.
Does this phenomenon occur with 2D elements if they were drawn in another storey? That is odd. I am only copying a set of grouped entities comprising arcs fills and text from the model space, which is a manual door/window schedule marker in 2D only, to an elevation window.
