Grouping
Is there any way to group stuff, like a wall and a slab for example, so when i want to move them they will move as a whole?
1 REPLY 1
Select the items you wish to group - Make sure groups are turned on - and under the tools pull-down, select "Groups" (or "CTRL" + "G" is the short cut)
When groups are turned on, the two elements will act together, with groups off, they are independent of each other.
