‎2023-10-04 03:57 PM
Hi! I have a problem with my model - when I select an element in 3D it's guidelines and nodes don't appear if its the whole model. If I isolate only the element, everything is fine. Any clue what would cause that. It worked perfectly until today. I put some screenshots for clarity.
Solved! Go to Solution.
‎2023-10-05 03:56 AM
I do not know the reason, but has anything been modelled very far from the Project Origin?
Or is the model itself far from the Project Origin?
Have you tried re-starting your PC?
‎2023-10-04 05:11 PM
That is a strange anomaly. Be sure to post what caused this when you figure it out.
Thanks.
‎2023-10-05 07:47 AM
No, this is the original model, this is why I was surprised. When I show a small marked area from the model everything is fine.
‎2023-10-05 07:48 AM
And this happens to other computers too.
‎2023-10-05
10:13 AM
‎2023-10-09
05:18 PM
Some details of which version of AC and revision number might help together with your OS.
Has anyone possibly changed any of these settings in the Work Environment?
‎2023-10-05 10:20 AM
This is AC 21.0.0.3005, on Windows 10. And no, the settings are as shown.
‎2023-10-05 10:29 AM
There has been 6 updates to version 21.
The newest is build 8002.
You should probably try installing that.
‎2023-10-09 10:06 AM
I have again inspected if something was modelled very far from the project origin, somehow my railings were moved on a very different level and I found and deleted them. That worked and now everything is fine. Thank a lot again.
