Gutter 10
Bruce
Once again ArchiCAD lets me down.
I have an irregularly shaped roof that necessitates an eaves gutter being on an angle.
I have tried the Cadimage roof builder, but for some reason it will put in a raked gutter that sits inside the roof envelope and won't show in section. I'm sick of e-mailing them with problems because I rarely get a response, and when I do it usually doesn't help.
So I thought I'd try the Gutter 10 that comes with AC. But the problem is that this gutter will only slope one way!!! I've tried flipping it, rotating it, mirroring it, putting in a negative angle, changing the anchor point - but no matter what I try I can't get it to slope the way I want.
Does anybody know how to make this sodding thing work?
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
4 REPLIES 4
I had no problem making gutter 10 pitch either way.
I used 1:12 and -1:12. Did you try setting the pitch
in terms of feet in twelve feet rather than degrees ?
Peter Devlin
Bruce
(if you're using half round gutter) can you rotate 180 degrees (in plan) or are you using hangers or K-style gutter, (and therefore its assymmetrical?).
I also tried, and found no other way of sloping in opposite direction. Can you get the ends to mitre correctly?
TomWaltz
Since you're on Archicad 10, just skip it.
Use the new Profiled beams. You can make them into whatever shape you need and they slope.
Tom Waltz
Bruce
Beams weren't suitable as I had to intersect two gutters at an odd angle and different slopes. I just used two roofs.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
