Gutter issues
Ive encountered this small issue where using a complex profile with a beam isnt connecting properly at corners.
I have two exact same houses, one the beams work perfectly as I need, and the other encounters a weird issue, even if I Drag a copy from the one which works to the other, it ends up the same way.
Could someone help with what might be causing this?
Thanks.
6 REPLIES 6
Are the beam reference lines trimming properly in plan?
i.e. no gaps or overlaps.
i ve found the same error when i paste an objet over the same objet.
If is not what Barry said, could also be the layer intersection Level.
DGSketcher
Legend
Are they exactly the same complex profile? If they aren't then you may have different materials in the complex profile.
Are you using modules?
Not too sure what was happening. Maybe was a graphical error as I did the same thing after restarting and there was no issue.
rgarand
If they are sharing a layer with something else, or touching a layer with the same intersection number, that would cause them react in this way.
Try putting them on their own layer then given them a unique intersection number.
Robert J. Garand
ArchiCAD USA 28-Build 6003 USA FULL and ArchiCAD USA 29-Build 3000 USA FULL
Windows 11 Prof (64 bit) - Intel i9-14900K CPU 3.20 GHz - 64 GB RAM - NVIDIA RTX 5000 Ada Generation
