2016-05-0210:21 AM - last edited on 2023-05-2612:27 PM by Rubia Torres
2016-05-0210:21 AM
Ive encountered this small issue where using a complex profile with a beam isnt connecting properly at corners.
I have two exact same houses, one the beams work perfectly as I need, and the other encounters a weird issue, even if I Drag a copy from the one which works to the other, it ends up the same way.
Could someone help with what might be causing this?
Are the beam reference lines trimming properly in plan?
i.e. no gaps or overlaps.
One of the forum moderators. Versions 6.5 to 27 i7-10700 @ 2.9Ghz, 32GB ram, GeForce RTX 2060 (6GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
