HELP, I can't Offset my Spline
I traced a GIF object and now I have a Grouped Spline. I need to Offset a portion or all of the edges of the Spline, but I can't. I've tried everything I can think of. I can make a Polyline and Offset the edges, so why can't I Offset the edges of my Spline?
6 Replies 6
Welcome to ac-talk: please use the Search link above (the text link in the white area - not the blue search button) to check to see if your question has been answered before posting.
Searching on "offset spline" brings up this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=123362#123362
with your answer.
Aaron Bourgoin
I offset my spline in a car accident once.
(sorry, couldn't resist)
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
That's what I needed. Works great. Thanks Karl! Aaron, my Dad got rid of his spline after his motorcycle accident. 😉
with your answer.
might be a dumb question but
Weston wrote:
the magic wand is the key to this operation...
step 1: what do you want to create with the offset? lines? - then pick the line (or pline) tool. A brick garden wall? - select the wall tool with appropriate settings.
step 2: hit the letter "o" to activate the offset button. you'll see it show up in the controls (?) pallette. It has the suspend groups switch on it, and the division settings... multiploe offset is right next to offset and it works the same way.
step 3: hold down spacebar to get the wand, move the cursor over the edge of the sidewalk until the polgon appears on the cursor (like the mercedes, or checkmark). Click the mouse to start the offset.
step 4: drag the offset to where you want it. for precision, enter a distance in the x,y, or radius/angle boxes.
HTH
Wes
when i push "o" nothing happenns for me?
Shortcut not assigned. Turn on your Windows> Palettes> Control Box palette and look for this puppy...
done and done
thanks
