2008-10-23
04:03 PM
2023-05-23
04:58 PM
Rubia Torres
2008-10-23 05:05 PM
2008-10-23 05:08 PM
2008-10-23 05:25 PM
2008-10-24 12:45 AM
Karl wrote:
Welcome to ac-talk: please use the Search link above (the text link in the white area - not the blue search button) to check to see if your question has been answered before posting.
Searching on "offset spline" brings up this thread:
http://archicad-talk.graphisoft.com/viewtopic.php?p=123362#123362
with your answer.
Weston wrote:
the magic wand is the key to this operation...
step 1: what do you want to create with the offset? lines? - then pick the line (or pline) tool. A brick garden wall? - select the wall tool with appropriate settings.
step 2: hit the letter "o" to activate the offset button. you'll see it show up in the controls (?) pallette. It has the suspend groups switch on it, and the division settings... multiploe offset is right next to offset and it works the same way.
step 3: hold down spacebar to get the wand, move the cursor over the edge of the sidewalk until the polgon appears on the cursor (like the mercedes, or checkmark). Click the mouse to start the offset.
step 4: drag the offset to where you want it. for precision, enter a distance in the x,y, or radius/angle boxes.
HTH
Wes
2008-10-24 02:22 AM
2008-10-24 02:45 AM
