HELP! Skylight tool corrupts my file
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2004-12-10 07:42 PM
I was hoping I could open the file and delete the skylight and reinsert them but the whole model has disappeared.
The bpn file has the same problem.
How can I recover my file?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-10 08:44 PM
However, I can't figure out how to get my saved views and stories merged from the old file.
Once again I do not want spend the time to clean up this file. If anyone knows of a way to open the old file without the offending skylights then I should be able to just re-insert new skylights once the original file opens correctly. For example, opening a file without the archicad library loading.....??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-13 05:13 PM
If anyone knows of a way to open the old file without the offending skylights then I should be able to just re-insert new skylights once the original file opens correctly. For example, opening a file without the archicad library loading.....??You could try temporarily moving the library to a a different location on your hard drive and then open the file and see if the file will open. The unloaded library objects will just show up as a dot so you might have to search a bit to find the skylight and delete it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-13 07:32 PM
No matter what I do the file loads but its just a black screen with no lines. The navigator shows the view sets but clicking on them brings nothing on the screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-14 02:04 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-14 06:34 PM
Jeff wrote:No. Someone (Link?) may know of a trick...?
Is there a way to import "View Sets" from another pln?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-14 11:30 PM
couldn't you make a duplicate of the file with the view sets, delete everything and then merge your .pln
bill
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-15 12:25 AM
I have upploaded the file that has the skylight error onto my ftp site. Please, please someone download it and try and open the file without the skylight error. I was able to merge it into a new file but I lose all the view sets that way.
You can download the file, "Hildner" (1.3mb) from the folder titled "Skylight Error" at:
http://www.modernmagic.com/files
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-17 08:50 AM
I got the same error, but continued on.
I can't yet get a 3D, but it looks like you have a 'garage object' and that is what is messing you up.
Is your model and/or module way way way far away in another galaxy to the left of the global origin? There has been documented problems with building/objects being placed far from the global origin. It used to be you didn't even place a building in anything but the positive X,Y quadrant.
That is where something keeps showing up but I can't zoom in on it.
If it is a skylight problem, it looks like well documented one with the way skylights cut holes in roofs; the upper-mostside is horizontal not vertical or perpendicular causing an inverted wedge of roof way way...galaxy.
When I selected the hotspot for a missing library part I tried 3 things.
1. put your settings on full error report and got an error of 0 seconds and no information
2. using the edit selection set button saw that there are over 150 items selected (see screen shot) so something is selected
3. Under windows, elements basic got a" wrong wall hole definition R01" error message. kept pressing continue and eventually got a short list of wall hole (only had the wall layer showing) and then a longer list (more layers showing) both started with 'GARAGE OBJECT'
If you want those reports email me privately.
I would check out the object and resave it and then retry it.
If there is a skylight in the object, try saving a version without it and see if it helps.
Hope this helps,
Perhaps someone else can take it further.
If you want the text of the
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-12-17 08:59 AM
I notice as I continue looking (no 3D yet) that you have a "hildner skylight"
see if this opens ok in a new file like testing the garage object.
Mac OSX 10.11.1
AC5-18
Onuma System
