HIDE Part of elevation??
keily
hey does anyone know how to hide part of elevation?? in the photo below there's a lot of ugliness below in the grounds as you can see stuff behind, but was wanting to know if you can hide or get rid of it but still keep the dimensions
Lee Hankins
If the dimensions have been added to the View, you may be able to change the vertical range of the elevation in the elevation settings to start at or just below floor level and the dimensions still be visible.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
amazing thankyou!
There is also this option (section/elevation range) which is available if you are currently viewing a section/elevation. It shows the limits graphically so you can adjust them exactly from within the view itself.
| AC 28 Int | Win10 | i7-7800X | 32 GB | GeForce RTX 2060 6GB |
