HOW ?
I checked everthing and i just cant get perimater units in meters, they are now in cm. How i can change this. This is in zone tool.
HELP PLZ
7 Replies 7
You mean in the zone stamp I assume. This depends on the specific stamp you are using. Try different ones to see if they will do what you want. No one will be able to answer you more specifically without knowing which stamp you are using.
im using zone_stamp_0210 archicad 10
Area is in meters and thats ok
but perimeter is in cm. I dont want cm i want that in meters
When i restart archicad i get this in meters, this is something in my template that i created so if anyone know where i can change this, help
One solution for me is to create new template and i know this will work for me, but we all want to know more so help !!!!
We don't have that stamp in the US so I can't check it here. I assume you have looked at the stamp's parameter settings. If not, you can check the individual settings in the zone settings dialog. You can also reset the default settings for the zone type in the attribute settings for the zone categories.
If you can't get this stamp to behave you may need to find a different one that works or fix this one in the GDL script editor to work the way you want. I don't recommend the latter choice unless you are fairly familiar with GDL. Even then the code in some of the standard parts can be quite confusing due to the many variables they have due to the wide range of users they serve.
Link
I thought the units for this was set by the 'Length Unit' setting at Options > Project Preferences > Calculation Units...
I don't know why this would change on it's own though?
Link.
That is possible depending on how the stamp is scripted.
It shouldn't. I am not sure what is happening in this case though.
I have retstarted archicad to fatctory setings and now everything is ok, THX ANYWAY !!!!
Djordje
HELP PLZ
Change your working units to meters.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
