‎2024-09-17 11:12 PM
I need a Handrail that is Horizontal to the ground at the end and begining, The Rail needs to extens 12" and return with (2) 90 degrees angles to the original end post. I only see the ability to have a "Candy-cane" end post that curves downward and not Horizontally to the ground.
Is this possible?
‎2024-09-18 01:07 AM
Decided to just make a Profile wall.
‎2024-09-18 02:46 AM
Probably the best way to do it.
That 'connected' end only works when you have a double sided handrail.
‎2024-09-18 03:28 AM - last edited on ‎2024-09-18 03:39 AM by Barry Kelly
Edit: better example.
Ling.
‎2024-09-18 04:30 AM
I was going to say, that second icon really needs to be changed to show horizontal.
But the end can actually be rotated - kind of.
I can rotate to vertical but not to the other side.
Also, once vertical, I can not rotate it back.
It may just be me doing something wrong.
But there are some not so obvious buttons in the settings that control the rotation just fine.
‎2024-09-18 06:04 AM
Rather than rotation, they are more controlling the direction of the radius.
