2010-06-27 02:00 PM
2010-07-28 03:55 PM
2010-07-28 10:24 PM
2010-07-28 10:40 PM
2010-08-22 10:35 PM
2010-10-15 05:15 PM
2010-10-15 10:30 PM
Chazz wrote:Yes this is still an issue. I have noticed that when I align the interior elevation marker up with the non-core lining of the wall it sometimes diseapears but I have not been having the problem since I started lining the marker extent line up with the core component of the wall and treating the lining as though it doesn't exist. I think this is some glitch with the entire model/core only display.
On the other hand, the interior elevation tool is still broken (the transparent wall issue).
2010-10-19 08:38 AM
Chazz wrote:I did not install 14, first hotfix not ready for the French version (NEVER install before 1st hotfix if you are an "ordinary user").
One bright spot in an otherwise poor upgrade: saving Open GL 3D window now actually works. For the last several versions, saved Open GL windows would give very strange and unusable results. This was true if the 3D window was saved as a JPG or saved as a view and placed on a layout. Sometimes I would need to take screenshots instead. Pretty poor for a 3D BIM tool..
