Have a problem Trim a Column with profile using SEO and TTR
Hi All, i have a problem when i trim column object with special profile.
there's a hole inside a column (see in a rec circle). anyone can solve this problem please?
Sorry my english is bad
It is kind of hard to figure out what is going on there because there are so many segments but:
You could also try to use a Solid Element Operation, with the object as Target, the Roof as Operator and using the "Subtraction with Upward Extrusion" SEO method.
Thank u Lazlo, i also try that way too and still have the problem but this day i get a solution...Thanks God, it just need to change Junction Order value fro 12 to 8 or below in the beam setting
