Have a problem Trim a Column with profile using SEO and TTR
Hi All, i have a problem when i trim column object with special profile.
there's a hole inside a column (see in a rec circle). anyone can solve this problem please?
Sorry my english is bad
2 Replies 2
It is kind of hard to figure out what is going on there because there are so many segments but:
You could also try to use a Solid Element Operation, with the object as Target, the Roof as Operator and using the "Subtraction with Upward Extrusion" SEO method.
Thank u Lazlo, i also try that way too and still have the problem but this day i get a solution...Thanks God, it just need to change Junction Order value fro 12 to 8 or below in the beam setting
