Heat loss calculator
Are there any add-ons (or features within ArchiCAD) that would allow calculation of U values (thermal resistance of walls / floors / roofs etc)?
Cheers
Matt
AC8.1V2.1 - Mac X
6 REPLIES 6
I don't know if there is anything ready made, but the potential exists in the calculate functions. You will have to make sure your walls, etc. have the necessary properties defined.
PS: I believe thermal resistance is "R" value. "U" value is the transmittance.
Thanks Matt
Right, I havent used the calculate functions so... is this easy and where should I look to learn how to use it??
And yes I was looking for transmittance, cheers for the corrction!
Matt
Djordje
Maybe here:
http://archicad-talk.graphisoft.com/viewtopic.php?t=2499
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Aaron Bourgoin
You might want to check out the freebies at Cymap. The QuickSlab tool will do what you want. navigate to: http://www.cymap.com/products/free.htm
We tried to see if Graphisoft could write this applivcation into the Composites Dialog box, but never heard anything back.
Aaron
Think Like a Spec Writer
AC4.55 through 28 / USA AC27-6010 USA
Rhino 8 Mac
MacOS 15.2
when wold be Cymap available in the US?? is there any hope for us
Cheers guys, the quickslab application seems to be PC only and the greenbuilding studio plugin is USA only. Silver lining is that GBS plugin is coming to the UK this year and might be an answer to guestimating energy consumption and thermal efficiency! Brilliant.
Waiting for the Uk release
Cheers
Matt
