Hedges - Best practice?
What's the best way to indicate a hedge in archicad please?
I only really need it for 2D purposes and the 3D hedges look like they could be a bit too heavy.
15 Replies 15
Aaron Bourgoin
if you manage to find a vector fill for hedge, could you share it? I've got a similar issue and the hedge doesn't section well.
Think Like a Spec Writer
MacBook M4Pro - 24Gb RAM
AC4.55 through 29 / AC29.2.1 USA
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
There are 'hedge' line types which can be used with lines & polylines for 2D hedges depending on your desired output
Aaron Bourgoin
Hi, Thanks. They aren't available here in North America.
Rhino 8.35 Mac
MacOS Tahoe 26.6.2
How frustrating!
In that case maybe create your own hedge symbol line?
https://helpcenter.graphisoft.com/tips/archicad/attributes/how-to-create-custom-line-types/
Could you share an empty file with those in please? Tried opening the Shoegnome template too but that didn't have the hedge linetype that you've indicated either.
Failing that I'll create something and post it.
With your key you can run any version of AC up to the version level of your key including the international version where you get access to the international library. And you can download the international version off of the Graphisoft website.
runxel
What an overkill!
Downloading and installing an entire program just for some lines? You have to be kidding me.
Maybe someone has mercy on us and might share!
«GeometricDescriptionLucas» | Lucas Becker | AC 30 on Mac (Sequoia) | Graphisoft Insider Panelist | Akroter.io – high-end GDL objects | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text
runxel wrote:
What an overkill!
You can't have the international library on, say a UK installation?
I've moved from Revit and you could use other content/libraries on the UK installation
runxel
Yes, you can. I wouldn't do it in a production file, tho.
But the libraries alone aren't meant for download (at least I don't know an easy way to get other localised libs. Many of them are also customized by resellers, e.g. in Switzerland).
