Hello Plz Can Someone Help Me ?
Hello there, am a french user of Archicad and i have a little problem.
Could you give me the march to make roof has several parts
(Maybe5) on archicad 11.
This is a link for a pics how show what i try to do :
thx a lot
5 REPLIES 5
Thomas Holm
Create mesh. Then Mesh-to-roof tool.
Yes i have try that i can create a roof with 1 level but how can i create 3 levels ?
UP
You need to use the PolyRoof geometry method of the Roof Tool. Check its description in the Help files.
Also, when you are actually creating the Roof, draw a Circle and SPACE-click it to use the Magic Wand functionality to create the 5 or sided polygon you need. Before doing that you have to set your Magic Wand settings correctly.
David Maudlin
GuillaumeMCA:
After you have created the plan shape (with walls or lines), select the Roof Tool, select the Polyroof Geometry Method, and Magic Wand the lines or walls. A dialog box will appear with options for the number of roof levels (as well as some other options) for the roof that will be automatically created.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
