Help Menu: Introduction to Object Making
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2005-10-25
02:28 AM
2023-05-23
05:18 PM
Rubia Torres
2005-10-25
02:28 AM
At the end of the introduction David Nicholson-Cole writes,
Where can I find the PDF version of this section?
There are other sections of the help menu that I would like to print oyut to read at home. Are these files avalible as PDFs?
Thank you,
John
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 03:30 AM
2005-10-25
03:30 AM
johncassel wrote:A tip to you and everyone else: Your AC 9 installation CD has quite a few PDF files with product documentation, including David's book. If you create a folder (if it does not exist) called "Documentation" under your AC 9 program folder, and copy all of these PDF's into it - they will all show up in your Help menu and be one click away. The 6 PDF manuals that are part of the US SE9 library should also be placed into this Documentation folder to be easily at-hand.
If you install the 2nd US CD (Training Guide), it does create the Documentation folder and copies the training PDF's properly. It is an installation flaw IMHO that the main installation does not install the PDFs.
AC 28 USA and earlier • macOS Sequoia 15.4, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 12:13 PM
2005-10-25
12:13 PM
Karl wrote:International does; this is US only.
For all with Int version:
C:\Program Files\Graphisoft\ArchiCAD 9\Graphisoft Documentation
C: might be something else in your case - that is the drive where you installed the 9
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
HP Omen
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 07:13 PM
2005-10-25
07:13 PM
Djordje wrote:Right ... I was speaking of the US version. Sorry for confusion to INT.
But, the above folder is wrong even for INT... the contents of that folder will not show up in the Help menu (unless INT does something different). You must rename it from "Graphisoft Docuementation" to "Documentation" and
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2005-10-25 07:26 PM
2005-10-25
07:26 PM
Karl,
Thank you,
John
Thank you,
John
